Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Have nested layer inherit the layer properties of parent layer
2 REPLIES 2
srookZD8Y9
131 Views, 2 Replies
We make heavy use of nested layers to keep our scenes organized between multiple artists. I've noticed that nested layers do not respect the layer property settings of its parent layer. For example, setting a parent layer to "Not Visible to Camera" will not filter down to the nested layers and and they will still render normally. Is there a way to make those settings propagate to all the nested layers?
2 REPLIES 2
MartinBeh
in reply to: srookZD8Y9
While normal scene objects can be set to "By Layer" mode in order to inherit the display settings of the layer they are on, I don't think Layers have the same ability, i.e. they cannot inherit settings from the layer they are nested into.
So I believe your objects will only accept their immediate parent layer as source for their "by layer" settings.
Short answer: No, I do not think there is a way to get this "out of the box". There are probably many ways to do this through custom scripts or tools like render pass managers, AOVs with expressions etc.
PS: If you are using Arnold, maybe its "Operator Graphs" might come handy? This https://veda3d.com/override-material-for-arnold/ might give you a start?
Martin Breidt
http://scripts.breidt.net
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
srookZD8Y9
Thanks for the info Martin. Looks like my next project will be to start looking into scripting. We are using VRay and Pulze.io's Scene Manger plugin as our render pass manager. For the most part everything works well. However, when dealing with a lot of layers for different setups, it gets tedious fast.
