hardware for 3ds max 2019
Hi, i've seen similar questions asked before but not for max 2019.
i'm new to 3d modeling and i'm ready to invest in a new computer.
a few questions:
how important is a desktop over a laptop? i don't really have the space currently for a desktop computer but could figure something out if needed to.
if i'm looking to spend around $2000, where should i put my money? (RAM, graphics card, CPU)
I'm not doing any heavy animations and i just use max, vray and photoshop. i want something fast though.
i do have a 1 tb ssd on my old laptop which i wonder if i can transfer to a new computer.
darawork
Here are the specs for 2019: http://help.autodesk.com/view/3DSMAX/2019/ENU/?guid=__interactive_help_reference_system_requirements...
Generally I prefer Desktops over Laptops, for a number of reasons. I find them to be harder wearing, both component wise and physically. Desktop parts can quite easily be upgraded for a number of years after purchase, whereas on a Laptop you are kinda stuck with what you initially get (aside from perhaps additional RAM). Desktops stay cooler, are less noisy and lastly, you're less likely to leave a Desktop on a bus by mistake.
You mention that you are using vRay, I presume the CPU render version, so in terms of priority I would choose the best CPU(s) you can afford, RAM secondary and lastly graphics card, in that order.
Your SSD drive can certainly be reused, as it will fit as standard into most machines.
Have a look on Dell Auctions, or the Dell Outlet store. Sometimes a nice Dual Xeon machine will pop up for in and around your budget price:
https://www.dellauction.com/   https://www.dell.com/en-ie/outlet
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
Hi, thanks for your response.
can you be a bit more specific as far as 'best' is concerned? choosing the right computer using that description is making me dizzy....
darawork
Hrm, I thought I explained it well enough... mustn't have.
vRay CPU powered = Get lots of fast CPUs, not much else matters. Although a
nice Graphics card is always nice to navigate inside big complicated scenes.
Here's a good link to read up on:
https://www.cgdirector.com/best-computer-3d-modeling-rendering/
Darawork
AutoDesk User
