somehow my move arrow gizmo that helps me move objects has turned into a pivot thing.
How can i revert to the normal gizmo?
Solved by Swordslayer. Go to Solution.
Solved by RadioRahim. Go to Solution.
never mind, I found that turning off the hierarchy tab and going back to create tab (on the right ) fixed this.
You might have accidentally pressed the Insert key, by default it's assigned to Affect Pivot Only.
argg this happened again, and i dont know what i pressed this time. It want insert though.
