3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Getting these "ghosted" windows popping up when using Hierarchy Right-Click Menu
9 ANTWORTEN 9
Nachricht 1 von 10
Mr.Mxyzptlk
251 Aufrufe, 9 Antworten
More specifically when I let go of right click these pop up. It's consistent.
Anyone ever had this issue and know a solution?
9 ANTWORTEN 9
Nachricht 2 von 10
MartinBeh
als Antwort auf: Mr.Mxyzptlk
No idea what this is but I noticed quite a few posts here on the forum with problems in rt-click and quad menus, maybe you want to search for some of them?
Martin Breidt
http://scripts.breidt.net
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Nachricht 3 von 10
Diffus3d
Seems to be an issue with W11 and the latest service pack.  (24H2 I think it is).
So far only confirmed by those with W11 and ASUS or Gigabyte motherboards.  Any chance you have one of those?
Best Regards,
Alfred (AJ) DeFlaminis
View Max Tips/Tricks Megathread
Nachricht 4 von 10
Mr.Mxyzptlk
als Antwort auf: Diffus3d
I have ASUS MB at work and at home. Only having this issue at the office.
Nachricht 5 von 10
Diffus3d
Make sure to file a support case to get this reported as many times as possible.  It's not surprising though, there are hundreds of issues with the latest w11 update across multiple industries.
Best Regards,
Nachricht 6 von 10
doug_bowker_3D
Similar problems for me as well. MSI MB in a custom workstation setup.
Doug Bowker
www.douglasbowker-motiongraphics.com
Nachricht 7 von 10
Diffus3d
Interesting, so we have mostly ASUS, 1 Gigabtye, and now 1 MSI.  The issue is affecting more than just 1 or 2 brands so perhaps m/b isn't a major factor but something else.   If a BIOS update doesn't fix it, then I think it's probably a driver problem of some kind.  But I'm only guessing.  The more data the support team has, the better.  Thanks!
Best Regards,
Nachricht 8 von 10
jibijib
I have this with Windows 10 in 2024 on a single wide monitor (2560 x 1440) - it looks like a problem with two or more monitors, or monitors with a resolution bigger than 1024x768, as it seems the Autodesk devs haven't been updated that people started upgrading from their 4:3 CRTs and 3DFX cards in the 2000's. :Gesicht_mit_Freudentränen:
Nachricht 9 von 10
Diffus3d
I have two 2550 x 1440 monitors on windows 10 and I don't have the issue.  RTX4090 and Asrock m/b.
Nachricht 10 von 10
jibijib
You must have a tired neck! :Gesicht_mit_Freudentränen:
The issue started when I began using the current monitor.
