Flight Studio Light Point Problem
When exporting light points from max to creator. I am getting pure white instead of color. How do you get the correct colors to transfer over to creator?
Things i have tried was vert coloring and giving it a material.I am not sure if color palette made in creator is causing issues or not. Any help would be greatly appreciated
Steve
Alfred.DeFlaminis
Hello Syounkin,
I have looked into this, and it appears be a known issue which we have logged in our defect tracking system. I can’t give you a definitive solution to your problem at this time, but I would suggest contacting the maker of Flight Studio to see if they have a workaround for the time being.
I apologize for the inconvenience, and will watch this issue in our system and report back if and when a solution for this problem is created.
Best regards,
