Fixed Normals not saving!
Some of my models have normals that needed fixing
So I fixed in 3ds max by selecting Editable Mesh> Polygon > Show Normals > Scale >0.01
yet when I export my file .fbx, and check it, the fixed normals aren't saved. Why does it do this?
sam_large
Hitting "show normals" is merely a viewport indicator to show you which way the normals are facing, try using "flip normals" under the Surface Properties section instead 🙂
That didn't work, it still looks the same after saving.
Are normals that appear like the screenshot a bad thing in anyway?
miledrizk
The size of normals, or the fact that they are visible or invisible doesn't change anything,
So don't worry.
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
thank you!
