I loaded a pretty heavy file in Max 2019. It has 4.8 million polys, lots of Forest Pro plants, Soulburn scripts in use, Relink Bitmaps loaded and a few other scripts active.
With the switch both "on" and "off", I see no difference in my FPS, interactivity fluidity in viewports, nor menu interactivity speed. I use a Space Pilot to navigate and am getting 3.1 FPS in a viewport with all 4.8 million polys visible. That doesn't change regardless of whether the switch is "on" or "off."
I'm glad that it helped @Anonymous . He did say he realized it might not be a solution for others. I currently don't see any difference but the next time I have a noticeable lag in Max 2019, I'll switch it off and see what happens. Right now, I just can't produce a lag that seems out of the ordinary as the low FPS I have right now is sort of typical for a file the size I'm using.
Rob Holmes
![EESignature EESignature](http://autodesk.i.lithium.com/t5/image/serverpage/image-id/1272565i464DC3DC646B4F11/image-size/original)
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
