Announcements
File fails to open after save, close open?
Hi! I'm having huge problems in a project currently, the file contains of two particle systems, its 11 MB in size, I'm running a dual xeon with 32 gb ram and a GTX 1060 6Gb GPU. As soon as I close and try to open this file again 3dsmax fails to open it? I've had to recreate this scene 10 times the last 2 days, it costs me time, money and hair on my head. Could someone help me with what causing this? File is attached. This particular version of the file I saved, turned off the particle systems (thought it could be an issue when loading the heavy particle systems), closed max, re opened max, opened the file and "An error has occurred and the application will close..." Best Regards Patrik
I found the problem myself!
I'm saving my files with the incremental setting, so I had 13 files that had been saved during yesterday.
I'm using the populate feature to get some animated people in my scene, and the files AFTER I added that is the files that crashes when I'm trying to open them. So its currently a bug in the populate system I would say...
I have submitted this as a bug as well
