3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
FBX Warning: Texture export Incompatibility
4 REPLIES 4
james.parker.37.ctr
445 Views, 4 Replies
I'm trying to export a model from 3Ds Max to import into Maya.
I select the model, File > Export Selected  chose my location to save and file format FBX.
I've have also tried Autodesk Media & Entertainment preset.
After I click OK button. I get the warning box. I can import into Maya but there are no materials on it the model is grey.
I'm using 3ds Max and Maya 2024, and Arnold Standard Shaders, the bumps are connected to the norm channel with a Arnold 2D Bump map.
Labels (3)
4 REPLIES 4
Have you tried using 3ds Max's 'Send To' option?  With Max and Maya open, you can do File->Send To ->Send to Maya and not have to export the FBX file at all.
Chris Medeck
I have, but it comes in as gray. No textures.
Textures attached to Arnold shaders cannot be exported for use in other applications, as far as I know.  Only standard (legacy), PBR, and Physical Materials are supported by FBX.  (as far as I know.)
Best Regards,
Alfred (AJ) DeFlaminis
View Max Tips/Tricks Megathread
Can you assign one of those materials to a cube or something and share it for a quick test?
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
