Error 3ds Max view
Error 3ds Max view
Message 1 of 10
Error 3ds Max view
hello, any one, have some issue same with me ?
im using 3ds max 2017 before 2016 not got this problem. any one have solution ?
this my SS of 3ds Max
tq if any one can help me
Replies (9)
Message 2 of 10
irishman_team_kilber
what type of VGA card are you using?
what service pack and got fix are you using?
have you updated direct X? if not here is the link https://www.microsoft.com/en-us/download/details.aspx?displaylang=en&id=35 if you type into the run box dxdiag then click on ok at the bottom it will give you the version number, the newest one is version 11
have you configured your VGA  in max correctly? if not then go to custom, preferences viewports, choose drivers and then choose revert from 3d you will get 3 options open GL, software and direct 3d make sure you have the correct one selected, check your VGA manual once you have then choose ok twice to close down these boxes close down max to take effect. then reload max back up.
Message 3 of 10
my pc spec
I7-4770
RX 480
- DirectX 12
- 3ds Max 2017 update 19.0 SP3 comercial
Message 4 of 10
that did not answer my question have you configure your VGA card in max correctly? does the lines go away when you configure your VGA drivers,
Message 5 of 10
yes, hm... i change the Customize > Prefrence > Viewport > Display Driver
from Nitrous Direct3D 11 to Nitrous Direct3D 9.0 , i think is solved heheh
Message 6 of 10
i would not say it works until you restart max and see if it works?
Message 7 of 10
yeah it.s works , but my max viewport go slowly if rotate the viewport T_T
Message 8 of 10
I'm not sure why your viewport is slow when you rotate the view all you did is change the display drivers maybe it's just a bug. what version of windows are you using if it's windows 10 then i think it's fully tested on there.
you have to wait until someone else chimes in
Sorry best of luck to you
Message 9 of 10
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
I've read through the thread here and I was hoping you might try something for me, please.  If you got back to DX11 and put an Edit Poly onto the stack, does the problem go away?  I would be grateful if you tried this for me.  Thanks!
Best Regards,
Message 10 of 10
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
