Error 3ds max error loading plugin dll error code 193
Muhammadhegazy
Observer Observer
Muhammadhegazy
Observer
Observer
I have a Error in 3ds max2020 error loading plugin DLL error code 193.
I need someone to help me to solve this problem.
10DSpace
@Muhammadhegazy
This error seems to point to something wrong with your installation of Max 2020.   An old link here:
https://forums.cgsociety.org/t/3ds-max-2013-error-code-193/1563687
indicates that Body_Object.dlo is the plugin for editable mesh objects and that re-install worked for the user who had the error.
I notice that your error message indicates that the path to the Body_Object.dlo on your system is to a G:\ drive ... Max 2019 subdirectory (instead of a Max 2020 subdirectory).  You say that you are running Max 2020, so it seems possible that your installation is messed up and that re-install would work.
Muhammadhegazy
Observer
Observer
thank you for providing assistance, and I have already visited this site and worked out the solution, but nothing happened and the problem still exists.
CiroCardoso3v
The code is different but is the same dlo file:
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/3ds-Ma...
When did you start getting this error? After installing a plugin or a script?
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
