Download 3ds max student install on other pc
Message 1 of 12
I am trying to figure out how to download 3ds max for students and install it on another pc without downloading again.
It´s just because my internet at home is not that fast. So I have to download it somewhere else.
Cheers
Twan
Replies (11)
Message 2 of 12
kennyj
I would suggest using the download manager; this will bring the install files onto your local machine.  (When you get to the install screen, look for the alternative options - it is usually a small link below the large download button.
You can then copy those files that are downloaded to CD and run on another computer.  I think you would need to install the download manager on the other machine(s) and I believe internet is still required for the install process, I don't think it is a full install without internet.  But it is still better than trying to run the full install on a slow connection.
Hope that helps,
Kenny
Message 3 of 12
irishman_team_kilber
Message 4 of 12
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
@kennyj has a good suggestion here.  There is one other option which is using the Virtual Agent and then you can download the parts easily as well.
Best Regards,
Message 5 of 12
Thanks good suggestion, but unfortunately I have to download with a Mac and need installation files for windows.
Message 6 of 12
Thanks, I am using the virtual Agent now.
But why are the files just 2.9 GB?
The normal download file is at least 6GB. Does that mean I still have to download a part?
Anyways thanks for your suggestion.
cheers Twan
Message 7 of 12
Alfred.DeFlaminis
The virtual agent should still be able to download the files in that case.  Does that work for you?
Best Regards,
Message 8 of 12
I can download it, but have to check it at home now if it´s the full installation.
Message 9 of 12
Alfred.DeFlaminis
It is, but I understand.  I'll follow up tomorrow and see how it went.  Thanks!
Best Regards,
Message 10 of 12
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
Message 11 of 12
Hi, thank you. Virtual Agent worked for me.
Message 12 of 12
Alfred.DeFlaminis
Glad to read that @Anonymous, thanks for the update and confirmation!
Best Regards,
