distorted rendered image
i have created a 3d model on archicad and imported it as a dwg file to 3ds max. i have inserted an HDR environment for the same. the model looks fine in the 3d viewport, like this..Capture.JPG
but after test rendering the session without any materials applied, im getting a fully distorted image like so.fail test.jpg
need immediate help. pls RSVP.
Francisco_Penaloza
Check for Double geometry, also Normals and check there is not displacement modifiers or materials.
Other than that you could apply a resetXFrom. What rendering engine are you using?
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
Is this still an issue for you?  Did the helpful comment by @Francisco_Penaloza help at all here?
It appears as if you are rendering an ortho view instead of your camera view.  Is this possible?  Can you please make sure that the currently selected viewport when you render is your camera view?  Or, can you check the F10->Common tab to make sure your render view isn't locked to an ortho viewport?
Would you please check those things for me?
Best Regards,
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
