Disable or change "Viewport Cycling" keyboard shortcut
pixelwash
Message 1 of 19
pixelwash
I want to use the new Windows 10 screen capture functionality in 3DSmax to make screen grabs of the viewport, and the keyboard shortcut for that is Windows-Shift-S, so when I press those keys, the 3dsmax UI flips into viewport toggle mode before I get to pressing the "S" key, and all I am left to "grab"is the floating viewport toggle UI, instead of the viewport alone.
Max tantilizingly offers an amazingly difficult to use UI to customize keyboard shortcuts, but it does not appear to either register the "Windows Shift" keyboard keys when I attempt to enter them into it, and I could not find "Viewport Cycling" as one of the commands to be customized anyway.
So I an stumped, and so I am asking how to solve my problem here.
Replies (18)
Message 2 of 19
Press Shift THEN WinKey+S instead of WinKey first.
Message 3 of 19
pixelwash
Yay! Not the most elegant solution, as it is all too easy to get the ordering wrong, and I would have preferred a solution which changed the keyboard command for windows cycling within 3dsmax, but doing this does let me to make screen grabs....
Message 4 of 19
jibijib
Or plug an XBox 360 controller in and use the big centre home button. 🙂
I'm glad they implemented this feature, ciao Fraps.
Message 5 of 19
danrod3d
How do I disable this entirely. I do not like the new shortcut for cycling through view ports since I use my own keyboard shortcuts for views. I am along time user of max, seasoned game artist and never complain hardly on new updates to max, but this is extremely annoying.
Thank you in advance
Message 6 of 19
jon79info
make it disappear
Message 7 of 19
CAMedeck
I actually really like this feature, and use it daily.  I used to toggle between full screen views and the 4 viewport layout constantly.  But when my model is complex, switching to all 4 views could be slow.  The ability to switch directly between two viewports, keeping them full screen, saves me a lot of time.
Chris Medeck
Message 8 of 19
jon79info
instead of key? cycling does make you think instead of direct neural pathway
Message 9 of 19
triffski
Ended up here after working out what was happening, checking the hotkey editor and facepalming for a few minutes - now I'm facepalming some more. 🙄
Autodesk really do know how to make Max hard to love at times, at least when Adobe try and mess with years of muscle memory they give you the option to disable it.
Message 10 of 19
artersr13
So, there are no solution to remove system reserved button from 3DS MAX shortcuts?
Only brain crutch to try work around that very controversial decision.
Shame.
Message 11 of 19
piXelicidio
I'm here also to complain. The new fancy Hotkey Editor is good, but if we can't modify the "Win+Shift" thing it breaks the whole purpose of workspace customization.
Message 12 of 19
-Riki
Very surprised this is hard coded into 3ds max.Its literally the most useful windows shortcut to take  quick screenshots. Please fix this Autodesk!
Message 13 of 19
CAMedeck
Hi @-Riki
As mentioned earlier the way to still get screenshots while in Max is to hold the Shift key, then hit Windows and then S.  This method will not invoke the viewport cycling.  So really nothing to 'fix'.
Chris Medeck
Message 14 of 19
-Riki
yeah I mean, its a workaround. Just a different hotkey than Im used to. Could be worse.
Message 15 of 19
artersr13
Am I right, Autodesk stuff KNEW the consequences of using reserved WIN key combination and HARDCODED this INTENTIONALLY? And now all artists must do workarounds because of Autodesk seems don't have QA department at all?
It's not hard to remember every time you stumble in this situation, re do that action «right» with "****, sure... That lamers from Autodesk! Huh..."
But there is the question. Is Autodesk really wanted that?
Message 16 of 19
medlenen
who missed the alt+w combination??? Why complicate things?
Message 17 of 19
piXelicidio
Imagine if every workaround to Max issues is labeled as a solution, therefore "nothing to fix"!
"Windows+Shift" is conflicting with operating-system-wide behavior. That's the real issue. Max can't force users into changing the way we use Windows.
Max has a powerful feature, of allowing keyboard customizations for almost everything. That's the fix, allow as to override that shortcut with something else.
Message 18 of 19
ka_0000
I agrre with this opinion. It should be at least customizable.
Sending screen captures is a common task.
Hardcoded WIN key short cut is a terrible decision.
Message 19 of 19
sadeghm
Community Visitor
Community Visitor
In 3ds Max, Shift+Win+S is a fixed shortcut that can't be changed. To avoid this issue, try not pressing all three keys simultaneously. Instead, hold Shift first, then press Win and S separately.
