disable cursor statistics display in 3ds Max 2022
danrod3d
danrod3d
Hello, I just installed 3ds Max 2022 and have noticed that when I am editing an editable poly object, my cursor now displays the amount of verts, faces, edges selected. We already have this in tot he right in the parameters area and I don't want to see this constantly displayed or showing up every time I select a sub-object component. How do I disable this? I have attached an image and video to show what I mean.
10DSpace
@danrod3d
Do you have Rappa Tools installed by any chance?  This came up in a recent post.
https://forums.autodesk.com/t5/3ds-max-forum/how-do-i-turn-off-vert-edge-numbers-hovering-next-to-mo...
Apparently there is a viewport statistics option in that Rappa Tools script that turns those stats you are seeing on.  You can disable the option.  The stats you are seeing are not a basic Max option and would need to be scripted.
(You are probably aware that Max's viewport statistics when enabled appear in the upper left under the viewport label and are something different).
danrod3d
@10DSpace Ah yes, I had just installed rappaTools when I noticed it. 🙏 Thank you very much for the heads up. This was driving me nuts. 🤓
