default scale , cm inch pixel ?
where do you go to see what unit of measure my 3DSMAX is using ? change option key ?
irishman_team_kilber
custom unit setup you have 2 boxes display units and then system units. don't mess around with these IMHO
so when i set height width and length of object to work on  what measure of unit is it ? CM INCH or Pixel ?
that depends on what you set them to in the first place if they are in default example US standard that is what they measure too,
you would also set the unit before you start modeling https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMa...
if you are gonna export your model into a game engine most game engines use meters or centermeters/centremeters,
where  can i find the system  units display dialogue window  to adjust ?
on the top menu you see custom, select that then go to units setup the first box you see is your units setup and then you display unit box, if you click that then max will display your display units,
