Data Channel Preset deleted - how do i restore?
I accidentally deleted the Auto Edge Crease Preset from the drop down list in the Data Channel Modifier. How do I restore it?
Thanks.
Jeff
Ok - figured this out
Navigate to:
C:\Users\<XXXX>\AppData\Local\Autodesk\3dsMax\20XX - 64bit\ENU\en-US\plugcfg\DataChannelPresets
Anything that was deleted will have a ".deleted" extension, remove this and restart max.
omarefr
Observer
Observer
hello good day, I have exactly the same problem, I don't know if I change the path to find that folder, but I have it in: C:\Program Files\Autodesk\3ds Max 2023\en-US\plugcfg\DataChannelPresets, the problem that I have is that nothing appears with the ".deleted" extension, I hope you can help me.
