Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hi, I have 3 Columns in my command panel, so I want to customize which rollout to be open, position, and order.
I was comfortable during modeling, but when it comes to CAT motion, every bone I click, the Layer Manager is close(sometimes open, randomly) It is so annoying.
Even I drag the little gray box in up-right corner, it reset after I click another object.
Is the any way to customize rollouts?
Solved by hagen.deloss. Go to Solution.
Hello @Anonymous,
Thanks for posting about your command panel drop-down issue on the forums! What version of 3DS max are you running?
I would recommend resetting your 3DS Max's settings, here is an article documenting how to do that.
I would also suggest making a custom toolbar for your most often used rigging tools, instructions on how to set that up is here, and i included a little picture too.
Hope this helps, please select the Accept as Solution button if my post solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
I didn't see an answer, did you answer his question?
He is asking customize Rollout panel and you telling him to create a toolbar? lol
