I've had the same blank curve editor and this brought it back for me:
1. Open curve editor.
2. Right click on empty space on the curve editor toolbar.
3. Choose 'Load Layout'.
4. Choose one of the other layouts. (Eg 'default')
5. Curve editor should suddenly start working again.
6. Change back to your preferred layout.
(Max 2018)
Hi @Anonymous,
Thanks for sharing your issue with us.
Do you have any updates applied to 3ds Max?
Did you try what @kerrin_taylor suggested?
I hope you are well.
other ways to try out are:
go to filters and under "Show Only:" section on the right section of the filter window turn off:
visible only, selected object only.
make sure you do not have the object hidden by default, also under the display tab of the command panel make sure you do not have filters on nor under the category tab do you have anything checked.
Hi @Anonymous,
Have you seen any information here that works as the solution to this thread?
If you could mark the right post as the solution it will help future visitors.
Many thanks!
