Dear Community,
I to you with what seems to me as a tricky problem. I hope it will be trivial for you to answer this.
I have imported an assembly model from inventor to 3ds Max.
I have selected one of the part of the assembly and added modifiers to apply a cross section view. This is to show the mechanism insides.
I have added slice, Edit Poly and Cap Holes. (note that it wouldn't let me use the modifier Cross Section.
Please have a look at the result in the attached pictures.
The three first picture should let you see that, I think, the geometry is closed.
4th picture shows the result I get where the cap is actually performed on the holes on the wrong face of the solid...
Nothing happens basicaly. No matter what type of cap hole option I select, or Edit poly (Vertex, border, edge...) it wont give me anything correct.
It seems to me this geometry is closed, so I don't get why is it failing to cap.
Would you please have a look and let me know what you think?
Thanks in advance,
Jules
