creating Maps
creating Maps
creating Maps
Good day,
I am working with Adobe Photoshop CS on Windows 7 Ultimate a Dell Precision 4600 Mobile Workstation, 3Ds Max 2015 and when I try to make a material map or change or alter a material map it seems after saving when I go back into Max and try to apply the map it has a lock on it. I go back into Photoshop and double click on the lock and it separates the two layers then if I attempt to save, save as copy with or with out layers, or even flatten the lock returns no matter what type of file I create to use as a map. Can someone help please. Thanks it is getting frustrating.
rendermaster
can you post a snap shot of what is the problem especially the lock you're mentioning.
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
rendermaster
Can you post a snap shot of what is the problem especially the lock you're mentioning.
Fadhil_Farook
Is that file set to STOP SHARING?
See Attachment
