create surface from spline
This widget could not be displayed.
I have a closed spline.When I apply extrude modifier to the spline.It is extruded in Z direction as default.Is there a way to extrude it along x axis.I am adding caps.Thank you...
jeff
What usually works is to go to the Spline level, select the spline sub-object(s), and rotate that. This will change the orientation before extrusion.
Max since 1992 (3d Studio) · Win 10-64 · Wintel workstation · 64 GB RAM · nVidia Quadro RTX 4000 · BB render garden via Deadline
