crazy rotate angles on slice plane modifier
hi,
putting a slice plane modifier on an extruded spline, i need to put 45 degree mitre cuts on it, when i rotate the slice plane 45 degrees you can see that it does not correctly rotate the slice plane 45 degrees, if it did , it would be aligned to the diagonal on the pink square,
this is crazy.....
how does this happen???
thanks
Tom
