Corona camera gets black only in one room
cardonblenden
New Member New Member
cardonblenden
New Member
New Member
I am rendering a house in 3dsmax corona and i have living room and dining room opened to each other by partition wall i render take shots in the living room normal no problem even i can see the dining room clearly through the shots but when i take the camera to the dining room the render is black i don't understand why please help!
MartinBeh
Hard to tell with so little detail on your scene, but make sure your camera is not accidentally inside some geometry.
Also check the render log, just in case something shows up.
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
wukanrulan
New Member
New Member
Well, something is blocking the camera or the exposure is off. Delete the camera. Position your viewport the way you want in perspective view, hit create corona camera button. Then render
