clear render output
clear render output
clear render output
Could you say how can I clear the render output path?
Steve_Curley
Not sure if you can, but if you don't want the render saved just uncheck the Save File option. Any particular reason you want it cleared?
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Yes, customer want clear path. I don't believe clearing path is impossible.
So I need make a full new scene? (render settings/material settings/assets..)
Steve_Curley
Make certain the Render Settings dialog is closed. Open the Maxscript Listener. Type the following into the pink part and press enter.
rendOutputFilename = ""
Max 2016 (SP1/EXT1)
thank you! it works!
Steve_Curley
Glad it helped 🙂
Max 2016 (SP1/EXT1)
Thanks for the solution, I get an issue if I move a project from C drive to the network for network rendering. Unable to complete the job and Backburner gives this error: 3dsmax adapter error:Autodesk 20.3 reported error:File Write Error;
Resetting the Render Output fixes this
