Cannot copy selected elements using shift-click or clone, behaves more like stretching
101380256
101380256
Hi I am trying to copy the selected elements using shift-click but when I drag the elements, instead of dragging a copy it drags as if stretching the elements. If someone can help me and maybe even include reasoning to show me how I should have reasoned the solution myself that would be very helpful.
RobH2
Can you upload that file? I'd like to try it and see what happens.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
File is attached. Ctrl+v works except it does not copy the selection it copies the whole parent element.
RobH2
I think it's just the how it works with the stack you have. Not everything works all the way up the stack. Sometimes you just have to collapse the stack and keep going. Make a backup of the stacked version but collapse a copy, drag your elements over and then delete the parts you don't want from the copy that copied too much. I think you just have to do a workaround on this one.
You could just 'Detach' the element you are trying to copy and then drag copy that detached mesh as many times as you want. Then reattach it later when you are done. That might be the easiest method.
Rob Holmes
