Announcements
Can't snap to face in top view(or Ortographic view)
raoul_emilian
raoul_emilian
Hello, it happens that when i am in Top view viewport(or ortographic), if i want to snap one object
to a face of another, it will dissapear and it's position will be x=100000000.0m,y=100000000.0m and z=100000000.0m. What's wrong ?
Replies (12)
MartinBeh
A bit hard to tell from the video what is going on. Have you tried switching to 2.5D or 2D snap mode, just to see whether this makes any difference?
Martin B   EESignature
โ†’ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
raoul_emilian
No,is the same.If i drag the spline vertex ,to snap to some faces, in some positions it's snapping and in other positions is dissapearing.It's happening only in top view or ortographic view.But in perspective view it's working.
MartinBeh
What are your snap settings when you try to do this?
raoul_emilian
I tried also using 2D,2.5D.
raoul_emilian
I tried also to rename the ENU folder but it's the same...
MartinBeh
And there is not, by any chance, some large polygon (e.g. sky) covering the entire scene, which gets snapped to in ortho view?
Can you post a minimal .max file that shows this, for us to play with?
raoul_emilian
It isn't something above the scene,i was looking for this.
MartinBeh
ยฏ\_(ใƒ„)_/ยฏ
raoul_emilian
Hey, here is the file.
raoul_emilian
Ok,i had to activate Backface Cull on the object properties,i dont know exactly why...
MartinBeh
Good find about the backface cull. I can confirm that snap is behaving much more benign if cull is on for the "BEND_ROAD1km001" object.
Without cull, it places the source "Box754" object at [100000000.0, 100000000.0, 100000000.0] if it cannot find a snap target point - Looks like a bug to me, and it only affects Face snap; Vertex snap, Midpoint snap and Edge snap work all fine with and without backface culling.
MartinBeh
PS: Somehow it is related to your "BEND_ROAD1km001" mesh - if I hide it and instead put some new geometry in its place, Face snap works like a charm...
