can`t select mirrored objects with backface cull checked
prince_taylor
prince_taylor
hi guys
i want to share with you the one thing that annoying me since 2017 and up to 2021 and for my workflow its essential if any one have solution for it will be very helpful
cause want to but i can`t i this issue is to short explain the issue is when backface cull checked on plane (which i turned on on all objects by default from preferences) and i mirror this plane it give it -100 in scale transform then CAN`t select the object from front face it can be selected only from backface which is not right 😟 until i reset XFORM the plane which is not convenient when iam using instanced objects.
prince_taylor
here is a video to explain more
martin.coven
There are two options when mirroring. Transform, which you are using and Geometry. If you don't want to invert your mesh, you will want to use the Geometry option.
Hope this helps!
Martin
Martin Coven
Senior Designer
prince_taylor
thanks but this is not a solution because it will just add mirror modifier to all instance objects basically will mirror all instance objects not just the one iam selected
martin.coven
Could you use references instead of instances? The issue is, as you know, when you mirror in geometry mode, it scales it by negative. You are essentially inverting it. There isn’t any other way to mirror something. We display the mesh with the normals still pointing the original way, but the mesh is truly inverted. When you turn on back face cull, it sees the geometry as pointing the other direction.
Martin Coven
Senior Designer
prince_taylor
hi
sorry for being late thanks martin its kind of workaround but not ideal solution for many reasons , the thing is in 3dsmax 2016 was fine and working very good can`t we get it to work like it was on 2016 please, I really want to upgrade to 2021 😕😭
prince_taylor
hi every body
no solution 😰 even after 3ds max 2022
any help 😔
