Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hi there guys! Recently ive been running into problems with 3ds Max, and decided to reinstall. Now im stuck near the 35% mark of downloading/installing, as the error directs me to Program Files > Common Files > Autodesk Shared> WSCommCntr4. I uninstalled every single program related to autodesk from Uninstall a Program function Windows 7, before I proceeded to a reinstall. Im in a really bad situation right now as I am needing it for class, and was wondering if anyone could help me out here. Thanks! If you need any further information please tell me and I would be happy to provide them to you.
Solved by darawork. Go to Solution.
WSCommCntr4 is a process that deals with the online InfoCenter activity for AutoDesk software. It might have stayed resident on your pc after the uninstall process.
Try going into task manager / processes and ending it (Highlight and press numeric Detele key, or right-click end process). Once it is not running any longer then try to reinstall the Autodesk software.
btw, I find I/Obit uninstaller standard a really good program for force-uninstalling software. Remember it for next time.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
