Can't align objects pivot
SEVALDALGN
Observer
SEVALDALGN
Observer
Observer
I have an Archicad model and try to make adjustments on 3ds max but here is the thing. Firstly imported objects have weird pivot locations I cannot understand. How can fix that for all geometries? Secondly, I made a hierarchy for the pivot, affect pivot only, and centered the object but when I select local aligned it doesn't change the direction. The box in the screenshot I created from max, the rectangle object is the imported model.
dmitriy.shpilevoy
I guess those objects have their transform reset so there is no information about initial orientation. You can try to restore it from bounding box.
Try this
https://www.scriptspot.com/3ds-max/scripts/fit-bounding-box
SEVALDALGN
Observer
Observer
Can this script align the pivot as I mentioned, perpendicular to the angular object?
