Can somebody please try to delete the xref object inside this file?
pproestos
pproestos
Can somebody please try to delete this xref entry?
Whetever I tried, is not possible to delete this remaining xref object.
And this is serious, because this error cannot be ignored and
appears everytime I open this file.
So in the case of batch rendering, all rendering jobs
stops because of this error.
Thank you very much.
raiden_xavier
Autodesk Support
Autodesk Support
Hi @pproestos,
Thanks for sharing your issue.
I will have a look at the file and let you know what I find.
raiden_xavier
Autodesk Support
Autodesk Support
Hi @pproestos,
1/3
What is the name of the xref in the scene? I had no issue removing anything in 3ds Max 2021.
2/3
Did you use the Scene Explorer to delete?
3/3
Perhaps reset the preferences? (in my sig)
Please see attached.
Look forward to hearing from you.
pproestos
thx @raiden_xavier !
Yes your advice to investigate better what was in my original max file,
showed me the way to find that was a forest pack object that
was pointed into a custom object that I have deleted in my xref file.
So as soon as I deleted this "ghost" forest pack , I was be able to clean
this xref trace that wasn't allow me to render in batch mode.
thx a million and God bless you for your support!
take care Raiden!
Petros.
raiden_xavier
Autodesk Support
Autodesk Support
Hi @pproestos,
Great to hear. You're very welcome.
Stay safe and happy Maxing!
