bug in max 2015 sp2 !
xujiebest
Message 1 of 30
xujiebest
max2015 in a line after the freeze, in principle, can not operate it, but you can still use the other wire line accath Flanagan frozen, why is this? There is max2015 options can be adjusted, or that it was a mistake BUG max2015 of? Max previous version did not meet this problem.
max2015里把一根线冻结以后,原则上是不能操作它了的,但是用另一根线依然可以accath那根冻结了的线,这是为什么?是max2015里有选项可以调,还是说这是max2015的一个错误BUG?以前的max版本没遇见这样的问题.
Replies (29)
Message 2 of 30
xujiebest
Message 3 of 30
xujiebest
Message 4 of 30
xujiebest
top
Message 5 of 30
xujiebest
mark
Message 6 of 30
xujiebest
mark
Message 7 of 30
xujiebest
mark!
Message 8 of 30
Stefan_L
Mark too.
Could you try to illustrate this issue in a slightly higher resolution?
Stefan
i7-2600 @ 3,4GHz, 32GB Ram,
512+128GB SSDs + 2x500GB HD
GeForce GTX 980 Ti 6GB + GTX 980 4GB
latest Driver (almost always)
Win7ProX64 SP1
Message 9 of 30
xujiebest
OK
Message 10 of 30
xujiebest
Message 11 of 30
xujiebest
Message 12 of 30
xujiebest
Message 13 of 30
xujiebest
Message 14 of 30
xujiebest
Message 16 of 30
Stefan_L
I don't know if I really get it. You can attach a frozen object?
I can't reproduce that here...
And I honestly doubt my post #8 is a solution to anything... 🙂
Stefan
Win7ProX64 SP1
Message 17 of 30
xujiebest
I want to can not absorb the frozen
not adsorption frozen objects In max2014
Message 18 of 30
felix
Well, I can. 😄 If a non-frozen object is selected, a frozen object can be attached through the attach button in the non-frozen object´s " Edit Geometry"-roll-out. I never really worked with frozen objects, so I couldn´t tell how it´s been in previous version.
Message 19 of 30
xujiebest
Frozen objects cannot be adsorbed in max2014
Message 20 of 30
xujiebest
mark
