Border is highlighted instead of polygon faces in percpective mode
ritterknight
ritterknight
A recent issue has occured when I try to click on the polygon, edge, or element, the percpective mode only highlights the wired border whereas the orthogonal views properly highlight the entire face. How do I change the face to be highlighted in perpective mode, rather than a border be highlighted?
raiden_xavier
Autodesk Support
Autodesk Support
Hi @ritterknight,
Thanks for sharing your issue with us.
Can you try the F2 key? Cannot recall where this is in the menus.
I hope that helps.
Many thanks.
ritterknight
Thanks very much. I realize it had to do with Soft Selection.
