boolcntrl.dlc and retimer.dlc contaminating the scene
Recently we found that some of our almost empty scenes are not reasonably big.
We tried all cleanup scripts and other solution with no results.
Moreover, creating totally new scene with size 67KB and merging the simple box from "contaminated" file and instantly deleting this box increases the file size to 1,424KB.
The only difference after that procedure we found in "File Properties" that new Plug-ins appeared are retimer.dlc and boolcntrl.dlc. (Please see attached picture)
We found and used the solution how to clean up the retimer (with no success although) but nothing about boolcntrl.dlc
We are not sure what is causing this and would really appreciate if you can help.
Thank you.
System: Windows 7, 3ds max 2014, Vray 3.20.02
PS. "Contaminated" big empty file is also attached
