Announcements
Blender add on Shrinkwrap in 3dsmax ?
Message 1 of 8
is there a script or modifier that does something similar to Blender Shrinkwrap modifier https://docs.blender.org/manual/en/dev/modeling/modifiers/deform/shrinkwrap.html
Replies (7)
Message 2 of 8
RGhost77
del
Royal Ghost | veda3d.com
Message 4 of 8
hagen.deloss
Hello @Anonymous
Thanks for coming to the forums with your question about a shrink wrap-like tool! I saw that @Swordslayer suggested the conform tool, which sounds pretty intuitive!
If you are looking for something with more nuance and control, I would suggest a cloth simulation with stitching, here is a good tutorial I found on that workflow.
Would love to give you more in depth help if you want it! Or to see the results of your shrink wrap adventures!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 5 of 8
I want to wrap any object for a low poly mesh shape instead of modeling and matching the shape
Message 6 of 8
hagen.deloss
@Anonymous
That sounds like a really good way to save time! and just to be sure, does the conform tool not get you the desired result? here is a little video demonstrating the tool and how to use it!
If this doesn't work for you, I would love to explore some other tools to get the desired effect.
Hagen Deloss
Message 7 of 8
That conform modifier  works super slow, it hangs MAx for minutes  with hi-res "wrap to" object (not so hi res actually . 2-3 mil of polys).    Blender  shrinkwrap modifier works with same thing just in real time.
 I wonder if there is another method for automatically conforming low res to hires model?
Message 8 of 8
well how do we do that with conform: https://youtu.be/YkUxB_bka3U?t=275
