Bitmap Panel Cropped at the Right Side in Slate Material Editor
Byteman
Byteman
A friend reported this issue with the old Composite Map, while its parameters are open in Slate Material Editor panel.
I wanted to see if its the same on my PC's - not the Composite Map but- Bitmap Map Type appears the same way.
Tried almost everything, from changing resolution to DPI Scaling... From deleting the ENU folder to individually deleting some INI files like SME.INI. Moving, detaching re-docking the panels...
Do you have any knowledge of this issue?
** Compact Material Editor is just fine in both maps.
Replies (9)
Diffus3d
That's a pretty thorough list and eliminates many of my suggestions.  Any chance 3dsmax is opening/starting on the 2ndary monitor instead of the primary monitor?
Best Regards,
Alfred (AJ) DeFlaminis
View Max Tips/Tricks Megathread
Byteman
No. Only one monitor in my case and so is in my friend's. I suspect the on board graphics card, which is disabled from the bios anyway. There is a GTX 1080TI on my PC and friend's is a laptop which also utilizes 2 graphics cards.
Diffus3d
That's a new one for me.  You'd think disabling it on the bios would hide that card.  I looked for some other ideas, and found these.  Shot in the dark.
Select the right GPU for 3dsmax/Maya/Motionbuilder  (#5-6)
Corrupted font
Best Regards,
Byteman
These did not help either. Must be something to do with specific hardware and computer settings. One of my PC's don't have this problem.
Diffus3d
I can't repro it either, but I don't have an on motherboard gpu.  You seem to have thought of everything I would try.  Sorry I couldn't be of more help on this.  The weirdest part about it is that it's two different map nodes on two different machines.
Best Regards
Chaiwat
same issue
Chaiwat
uncheck the Unicode UTF-8 in windows language settings.
it is fixed.
Byteman
Unintentionally replied myself. Sorry 🙂
Byteman
I couldn't have an opportunity yet, to check if it works, but it definitely makes sense. I turn it on for correct Turkish characters in some programs. Thank you for taking the time to answer.
Tags (0)
