I need to integrate 3ds max into a java driven flow. The java code is reading several 3d models files and associated metadata and must invoke a 3ds max job to create a new model based on the original files (think adding a sphere on top of a cube) and export it as a new file.
Is it possible to run 3ds max from outside and to execute job tasks? Are there any dedicated services to do this?
Hi @Anonymous
Thanks for bringing your question to the forums, it looks like you are visiting as a new member to the 3DS Max forum. I want to extend a warm welcome to the Autodesk Community!
I would say this is a question for the Autodesk Developers Network.
You may also have luck posting this to the programming forums for 3ds Max.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
@Anonymous
Any ideas or questions on my previous post? It would be helpful if you had time to give an update, that way other Community Members can benefit from your process 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
