Backburner error
Backburner error
rob_hart
Message 1 of 1
Backburner error
rob_hart
When trying to render some files using Backburner 2019, across a network, using an up to date (recently re-installed , Back Burner) throws out the following issue when trying to render with high Vray settings, in Progressive mode. Brute Force/ Light cache for the GI first and secondary. About 15 minutes in the Render window on the computer, (spec as previously stated) just crashes and the following error pops up in the error section in Backburner;
3dsmax adapter error: Autodesk 25.3 reported error: An unexpected exception has occurred in the network renderer and its terminating: 3ds max adapter error. The pipe has ended : 109 3ds max adapter error : The pipe has been ended : 109 3ds max adapter error.
The only way I could get this file to render across the Network using Back Burner was with Bucket also with high Vray settings. My go to workflow is always, the Network route with Progressive settings is my go to workflow..
Do you or any of the Community have any suggestions? This is not an isolated file, and welcome any helpful comments? solutions?
Replies (0)
