Hello, title is a bit misleading, but I don't know how to say it shortly.
The issue is as follows.
Certain modifiers, like boolean, are lagging with the complex objects, so very often, after applying boolean, I have to apply convert to editable poly, to reduce slowdown. This means, initial objects are lost, and can't be edited any more after save. So it would be nice, that somehow, when you apply convert to poly, or other "destructive" modifier, a copy of file would be saved with different name, so in case of need, you can always go back.
Like filename was test.max, I applied convert to poly to object, and there's a new save version like test.01.max, which contains that object, already converted to poly, and also, test.max also was saved, but without that modifier, just on a step before applying it.
Is this possible?
