Hello. I am currently using the 2023 version.
I found that if this function is assigned to a hotkey, then it either does not work, or works under strange circumstances.
I have this combination shift +h . On earlier versions, everything worked fine (in the latest, some oddities began, but in general it worked)
Now I clearly see - the selected object - I press the combination - it does not work.
I'm checking to see if it works. I create a box, I press the combination - everything works. Again I select my objects that I want to leave in the scene, and hide the rest. I press the combination - it does not work. This is very annoying, isn't it?
Have you tried pressing "Keyboard Shortcut Override Toggle" first?
You can activate/deactivate this function by typing Alt+Shift+Ctrl+X.
yes,he is on, but not working again.
I noticed that if there is a modifier, such as Symmetry, then it works. If working with an open Editable poly (or edit poly modifier) then - no.
Of course I tried. I do not know how else this "jamming" is so that it works adequately
Did you check in the Hotkey Editor if there's any conflict with your shortcut combination?
