Ase export multiple objects, only the 2nd has animations
AndreaTJHX7
Observer Observer
AndreaTJHX7
Observer
Observer
I have a scene with two objects.
Both are animated across 3 frames (rotation, scale, vertices are manually moved etc.)
They haven't been linked or attached to one each other in any way.
When I export to ASE, only the second  GEOMOBJECT has multiple meshes, one for each timevalue.
The first GEOMOBJECT has only timevalue 0
What am I missing?
MartinBeh
This might not be much help but ASE is an ancient file format. I doubt anything has been done to it since 3D Studio Max 1.0.
Any chance to use a different format?
PS: I just tried to set up a scene like you describe (with two animated boxes) and export to ASE, and this is what I get:
*3DSMAX_ASCIIEXPORT	200
*COMMENT "AsciiExport Version  2.00 - Sun May 25 11:39:53 2025"
*SCENE {
	*SCENE_FILENAME ""
	*SCENE_FIRSTFRAME 0
	*SCENE_LASTFRAME 100
	*SCENE_FRAMESPEED 30
	*SCENE_TICKSPERFRAME 160
	*SCENE_BACKGROUND_STATIC 0.0000	0.0000	0.0000
	*SCENE_AMBIENT_STATIC 0.0000	0.0000	0.0000
*MATERIAL_LIST {
	*MATERIAL_COUNT 0
*GEOMOBJECT {
	*NODE_NAME "Box001"
	*NODE_TM {
		*NODE_NAME "Box001"
		*INHERIT_POS 0 0 0
		*INHERIT_ROT 0 0 0
		*INHERIT_SCL 0 0 0
		*TM_ROW0 1.0000	0.0000	0.0000
		*TM_ROW1 0.0000	1.0000	0.0000
		*TM_ROW2 0.0000	0.0000	1.0000
		*TM_ROW3 -30.3431	49.0504	0.0000
		*TM_POS -30.3431	49.0504	0.0000
		*TM_ROTAXIS 0.0000	0.0000	0.0000
		*TM_ROTANGLE 0.0000
		*TM_SCALE 1.0000	1.0000	1.0000
		*TM_SCALEAXIS 0.0000	0.0000	0.0000
		*TM_SCALEAXISANG 0.0000
	*MESH {
		*TIMEVALUE 0
		*MESH_NUMVERTEX 8
		*MESH_NUMFACES 12
		*MESH_VERTEX_LIST {
			*MESH_VERTEX    0	-42.1521	35.2955	0.0000
			*MESH_VERTEX    1	-18.5341	35.2955	0.0000
			*MESH_VERTEX    2	-42.1521	62.8053	0.0000
			*MESH_VERTEX    3	-18.5341	62.8053	0.0000
			*MESH_VERTEX    4	-42.1521	35.2955	42.2362
			*MESH_VERTEX    5	-18.5341	35.2955	42.2362
			*MESH_VERTEX    6	-42.1521	62.8053	42.2362
			*MESH_VERTEX    7	-18.5341	62.8053	42.2362
		*MESH_FACE_LIST {
			*MESH_FACE    0:    A:    0 B:    2 C:    3 AB:    1 BC:    1 CA:    0	 *MESH_SMOOTHING 2 	*MESH_MTLID 1
			*MESH_FACE    1:    A:    3 B:    1 C:    0 AB:    1 BC:    1 CA:    0	 *MESH_SMOOTHING 2 	*MESH_MTLID 1
			*MESH_FACE    2:    A:    4 B:    5 C:    7 AB:    1 BC:    1 CA:    0	 *MESH_SMOOTHING 3 	*MESH_MTLID 0
			*MESH_FACE    3:    A:    7 B:    6 C:    4 AB:    1 BC:    1 CA:    0	 *MESH_SMOOTHING 3 	*MESH_MTLID 0
			*MESH_FACE    4:    A:    0 B:    1 C:    5 AB:    1 BC:    1 CA:    0	 *MESH_SMOOTHING 4 	*MESH_MTLID 4
			*MESH_FACE    5:    A:    5 B:    4 C:    0 AB:    1 BC:    1 CA:    0	 *MESH_SMOOTHING 4 	*MESH_MTLID 4
			*MESH_FACE    6:    A:    1 B:    3 C:    7 AB:    1 BC:    1 CA:    0	 *MESH_SMOOTHING 5 	*MESH_MTLID 3
			*MESH_FACE    7:    A:    7 B:    5 C:    1 AB:    1 BC:    1 CA:    0	 *MESH_SMOOTHING 5 	*MESH_MTLID 3
			*MESH_FACE    8:    A:    3 B:    2 C:    6 AB:    1 BC:    1 CA:    0	 *MESH_SMOOTHING 6 	*MESH_MTLID 5
			*MESH_FACE    9:    A:    6 B:    7 C:    3 AB:    1 BC:    1 CA:    0	 *MESH_SMOOTHING 6 	*MESH_MTLID 5
			*MESH_FACE   10:    A:    2 B:    0 C:    4 AB:    1 BC:    1 CA:    0	 *MESH_SMOOTHING 7 	*MESH_MTLID 2
			*MESH_FACE   11:    A:    4 B:    6 C:    2 AB:    1 BC:    1 CA:    0	 *MESH_SMOOTHING 7 	*MESH_MTLID 2
	*PROP_MOTIONBLUR 0
	*PROP_CASTSHADOW 1
	*PROP_RECVSHADOW 1
	*TM_ANIMATION {
		*NODE_NAME "Box001"
		*CONTROL_POS_TRACK {
			*CONTROL_POS_SAMPLE 0	-30.3431	49.0504	0.0000
			*CONTROL_POS_SAMPLE 800	-14.8068	67.1665	0.0000
		*CONTROL_ROT_TRACK {
			*CONTROL_ROT_SAMPLE 800	0.7055	-0.1379	0.6952	0.6894
		*CONTROL_SCALE_TRACK {
			*CONTROL_SCALE_SAMPLE 0	1.0000	1.0000	1.0000 0.0000	0.0000	0.0000	0.0000
			*CONTROL_SCALE_SAMPLE 800	1.6289	1.6289	1.6289 -0.2411	-0.0892	-0.9664	0.6930
	*WIREFRAME_COLOR 0.4706	0.4314	0.0863
	*MESH_ANIMATION {
		*MESH {
			*TIMEVALUE 0
			*MESH_NUMVERTEX 8
			*MESH_NUMFACES 12
			*MESH_VERTEX_LIST {
			*MESH_FACE_LIST {
		*MESH {
			*TIMEVALUE 320
			*MESH_NUMVERTEX 8
			*MESH_NUMFACES 12
			*MESH_VERTEX_LIST {
				*MESH_VERTEX    0	-100.9114	58.7131	10.0761
				*MESH_VERTEX    1	-7.1872	40.8479	11.0115
				*MESH_VERTEX    2	-82.0925	93.4851	-11.0115
				*MESH_VERTEX    3	11.6317	75.6199	-10.0761
				*MESH_VERTEX    4	-27.5082	88.0781	70.7562
				*MESH_VERTEX    5	6.5498	70.2129	71.6916
				*MESH_VERTEX    6	-8.6893	122.8502	49.6686
				*MESH_VERTEX    7	25.3687	104.9850	50.6040
			*MESH_FACE_LIST {
*GEOMOBJECT {
	*NODE_NAME "Box002"
	*NODE_TM {
		*NODE_NAME "Box002"
		*INHERIT_POS 0 0 0
		*INHERIT_ROT 0 0 0
		*INHERIT_SCL 0 0 0
		*TM_ROW3 22.0892	-54.5110	0.0000
		*TM_POS 22.0892	-54.5110	0.0000
		*TM_ROTANGLE 0.0000
	*MESH {
		*TIMEVALUE 0
		*MESH_NUMVERTEX 8
		*MESH_NUMFACES 12
		*MESH_VERTEX_LIST {
			*MESH_VERTEX    0	7.4368	-64.2018	0.0000
			*MESH_VERTEX    1	36.7416	-64.2018	0.0000
			*MESH_VERTEX    2	7.4368	-44.8201	0.0000
			*MESH_VERTEX    3	36.7416	-44.8201	0.0000
			*MESH_VERTEX    4	7.4368	-64.2018	40.2062
			*MESH_VERTEX    5	36.7416	-64.2018	40.2062
			*MESH_VERTEX    6	7.4368	-44.8201	40.2062
			*MESH_VERTEX    7	36.7416	-44.8201	40.2062
		*MESH_FACE_LIST {
	*PROP_MOTIONBLUR 0
	*PROP_CASTSHADOW 1
	*PROP_RECVSHADOW 1
	*TM_ANIMATION {
		*NODE_NAME "Box002"
			*CONTROL_POS_SAMPLE 0	22.0892	-54.5110	0.0000
			*CONTROL_POS_SAMPLE 800	7.6987	-57.4942	0.0000
			*CONTROL_ROT_SAMPLE 800	0.0000	0.0000	1.0000	0.7056
			*CONTROL_SCALE_SAMPLE 800	1.0000	0.8149	0.8149 -0.0000	-0.0000	-1.0000	0.7056
	*WIREFRAME_COLOR 0.8196	0.7765	0.4000
	*MESH_ANIMATION {
		*MESH {
			*TIMEVALUE 0
			*MESH_NUMVERTEX 8
			*MESH_NUMFACES 12
			*MESH_VERTEX_LIST {
			*MESH_FACE_LIST {
		*MESH {
			*TIMEVALUE 320
			*MESH_NUMVERTEX 8
			*MESH_NUMFACES 12
			*MESH_VERTEX_LIST {
				*MESH_VERTEX    0	-9.7395	-55.7624	0.0000
				*MESH_VERTEX    1	12.5679	-71.2492	0.0000
				*MESH_VERTEX    2	2.8295	-43.7393	0.0000
				*MESH_VERTEX    3	25.1369	-59.2261	0.0000
				*MESH_VERTEX    4	-9.7395	-55.7624	85.3801
				*MESH_VERTEX    5	12.5679	-71.2492	32.7649
				*MESH_VERTEX    6	2.8295	-43.7393	32.7649
				*MESH_VERTEX    7	25.1369	-59.2261	32.7649
			*MESH_FACE_LIST {
looks ok to me?
(except that for rotations there seems to be only a single key frame - there is only one CONTROL_ROT_SAMPLE for t=800, none for t=0)
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
