Hi, I've found that with Max2017 ServicePack1 the Art Render is working fine with Composite Map. After upgrading to ServicePack2 - it is NOT WORKING anymore. So I downgraded to SP1 and it is working again.
I hope that SP3 will correct that issue.
Bartosz
Hello @bborecki,
Thank you for the post and welcome to the community!
Yes, you are correct. Currently the composite map is not supported by the ART renderer. Even in SP1 you may run into issues with it. Thank you for reporting it however, in cases where it's an issue that's not in the system I will always log it so it's worth mentioning whenever you find something like this.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
