Apply material for different walls When use Link AutoCAD?
travis.designer.vn
travis.designer.vn
Hi
I use Like AutoCAD file from AutoCAD Architecture. There are 2 walls seperately, I try to apply 2 kind of material for each wall. But They always applied for 2 walls, same material.
How can I fix it?
Thank
BenBisares
Autodesk Support
Autodesk Support
Seems to be working fine for me. I'm just dragging and dropping different materials to the individual walls.
Ben Bisares
travis.designer.vn
Hi @BenBisares
I did same as you,  watch this screencast for datail:
Did you Link DWG or Import?
BenBisares
Autodesk Support
Autodesk Support
I just opened your file which had the DWG linked.
Do you have "Propagate Materials to Instances" enabled?
Ben Bisares
travis.designer.vn
Hi @BenBisares
You're right. It works when I uncheck. First time I confront this issue.
Thank you
BenBisares
Autodesk Support
Autodesk Support
No problem! I'll be honest I haven't used that option in a long time, to the point that I almost forgot that it existed.
Ben Bisares
