Animate splines to show architecture being built
trinitifx
trinitifx
I need to automate the animation of splines to show architecture being built.
Similar to this:
https://www.facebook.com/futurism/videos/846329178879616/
Not just slicing a completed model, I'd like to show it 'growing' with blueprint lines etc.
Can this be done natively, or with a script or plugin?
silentboof
Well on the spline itself I can't think of anything. But you can turn the splines to meshes and use particle face creator  modifier to get a growing effect on anything. It's actually very easy to setup. Search the modifier I mentioned to find the tutorials. If you couldn't find a proper solution let me know to explain more.
rode3d
This is the perfect plugin for you:
TurboSplines, from SplineDynamics.
http://www.splinedynamics.com/turbosplines/
leeminardi
Another approach is to use lofted shapes to define the beams and then animate the scale factor from 0 (for no beam) and 100 (for the fully shaped beam).  The scale factor can be keyframed to control the speed and portion of the spline that becomes "visible".
lee.minardi
