Advice on which computer?
hawk911
hawk911
I am trying to set up a small render farm. I bought a notebook on sale to use only as a render node but havent opened it yet. Specs are:
  • 2.6 GHz Intel Core i7-9750H Six-Core
  • 16GB DDR4 | 512GB NVMe PCIe SSD
  • NVIDIA GeForce GTX 1650 (4GB GDDR5)
I am wondering if I need to spend $400 more and get this one instead:
  • 16GB DDR4 RAM | 1TB PCIe M.2 SSD
  • NVIDIA GeForce RTX 2060 GPU (6GB)
Or if I need to bite the bullet and spend a lot more and get an RTX 2080.
Is an i9 preferable to an i7?
The plan is to use whatever new computer I get as a render node. The main computer running 3ds Max has 64GB RAM.  I will be using V-ray 3.X, Phoenix FD4, Mental Ray, and scan line render.  3ds Max 2017 and 2020.
I am mainly trying to speed up my v-ray renders and Phoenix because they take a really really long time.
A few years from now I will likely upgrade to V-ray Next but it will be a few years so an RTX card may not be worth it.
Thank you in advance for any help.
Richard.Vivanco
Go to i9 with six or eight cores and more frequency.
If you are planning to render with gpu go to rtx2060 plus, if not, choose a more powerful cpu and more ram 32-64gb
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Youtube | LinkedIn
autodesk 3DS pro
StephenMF
Spend some time on this blender site.
Lots of tests, that will help you decide.
https://opendata.blender.org/
hawk911
Thank you.  I am sending the unopened laptop back and going to get a desktop.
Maybe with an RTX 2080ti.
One of the things I am unsure about is since I am mainly trying to speed up v-ray3 and phoenix fd 4, if I need to spend more on processor or GPU
hawk911
New plan. I am now looking to get a desktop superior to everything I have and use it as main max workstation and sometimes use it as render node connected to other workstation
Looking at these two now:
3.3 GHz Intel Core i9-9820X Ten-Core
32GB of 2666 MHz DDR4 RAM (128GB Max)
512GB NVMe PCIe M.2 SSD
NVIDIA Quadro RTX 4000 (8GB GDDR6)
3.6 GHz Intel Core i9-9900K Eight-Core
32GB DDR4 266MHz (64GB Max)
512GB NVMe SSD + 2TB HDD
NVIDIA GeForce RTX 2080 Ti (11GB GDDR6)
Thoughts?
Quadro RTX 4000 over RTX 2080ti?
3.3 Ghz 10 core over 3.6GHz 8 core?
I am using v-ray 3.7, phoenix FD, mental ray and scanline
10DSpace
Hi @hawk911
I am not expert enough to answer the  Quadro RTX 4000 over RTX 2080ti? or the 3.3 Ghz 10 core over 3.6GHz 8 core? questions but a few lesser comments for what they are worth:
In building my machine a few years ago, I wondered whether I should go with 64GB vs 32 GB RAM since I typically have 2 different versions and/or instances of Max open at the same time along with Photoshop, Substance Painter,  Zbrush, and usually several desktop apps like Microsoft One Note and Word and Google Chrome.    I have not had an issue with 32 GB RAM despite the multiple apps.   If you have similar or less simultaneous app usage, you should be OK with 32GB RAM.   I mention this in case you had any doubts about that.
On the other hand, I did upgrade to a 1TB SSD and the price difference between 512 GB & 1TB must be now around only 50 bucks or so.  So relative to the overall costs of the system, I would be inclined to go for a 1TB SSD.  The primary apps that you want running on the SSD C drive are getting bigger and bigger so this is some future-proofing perhaps.
hawk911
Thank you very much.
I agree that the drive is too small and 1TB SSD is needed, but that is what it comes with so I am looking at other places/models to buy.
I only plan on running one program at a time and also upgrading to 64GB.
And I am also thinking of getting a Ryzen 9 3900X CPU with 3200Mhz RAM instead of the i9 due to some recoemmendations of 3D people.
I am unsure.
