Absolute path setup
Absolute path setup
Absolute path setup
Hi all,
So I want to set up absolute path for the textures of several object libraries like evermotion, first I added the texture paths folder in the Configure user paths, external files, but when I open any max file from this libraries and go to the Asset tracking the path status is shown as "found" and I need to select all textures, right click and choose "Make path absolute", so my question is, is it there a way to configure max so when I open or merge models the asset tracking would make all path absolute automatically??
Alfred.DeFlaminis
Hello @Anonymous,
I've done quite a bit of testing here and it seems that there is not.  You can set new textures to have UNC paths relative paths but when a file was created somewhere else and moved to a new machine with new pathing for textures, there doesn't seem to be a method I could find to do this without user interaction.  Since opening all the Evermotion files and setting the proper paths there seems like much more work, your current method seems the best.
Technically the paths are absolute by default, but the problem is that these file were created with a different drive lettering system so that 'absolute' quality is problematic when opening on a new machine.
Best Regards,
Hi Alfred,
Thanks for taking time in testing this, then I guess that the only solution left would be at least to create a script that would set absolute paths without the need of manually open the asset tracking and do all that process.
Alfred.DeFlaminis
Hello @Anonymous,
I think you may be correct.  It's an important enough script that if you do write one you could probably sell it for a few bucks somewhere.  I can see the demand for it.  I have 4 tree packs from Evermotion and for the first one I updated the paths in each file but when I got the the 2nd pack I ran out of steam.  I've been using the asset tracker (as you are in 1st post) since, but it does seem like there is some room for improvement there.
Best Regards,
