Announcements
About an issue when applying a diffuse map
Hello everyone,
I'm using 3DS Max 2016.
I have a part of a model (a display).
As you can see on the picture attached, the diffuse map perfectly matches with the UV map.
But when I assign a material and display the result in the viewport, the texture is like stretched out.
Where does it come from?
Thanks a lot.
RobH2
You've likely solved this by now but when that happens again you can detach just that single face, assign a UVW Map to it so it fills the UV space and reassign just the face diffuse map to just that mesh. It's a fast fix until you have time to further diagnose the other problem.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Hi.
Yes I solved it.
It was a little bit silly!
In front of the display you have a glass.
When I dragged the material, it applied to the glass and not the display.
Since I hadn't the correct UV map on the glass, it was stretched out.
RobH2
Great, glad you solved it. Max is very powerful and sometimes these little things can drive you crazy. Glad it worked out.
Rob Holmes
