3dsmax Grid Numbers
3dsmax Grid Numbers
3dsmax Grid Numbers
Can I see especific numbers on the grids in the 3dsmax interface.
Thank you,
Frank
hagen.deloss
Hi @Anonymous
Thanks for posting your question on the forums! All the information on customized grid settings I know is located here. I would say a route you could go is a texture map with the units aligned to the grid with the same settings could get you the results you want! ( my example grid isn't aligned very accurately)
I hope this helps out. Oh, another tool you can use to help with precision in 3DS Max is the measure distance tool.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
hagen.deloss
@Anonymous
Hello! I wanted to check back and see if my post helped you with your problem. It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Hagen Deloss
