Announcements
3dsmax 2024/2025 - Volume Select with mesh doesn't update and crashes
SamuelEeckhaut
Community Visitor
SamuelEeckhaut
Community Visitor
Community Visitor
Since we use 3ds Max 2024 or 2025, we experience issues with the volume select modifier.
The situation:
- A plane with some subdivision and a line (+edit poly modifier) we want to use as the selection;
- When adding volume select on the plane and the line as mesh object we get the following (so far so good):
But the problem now is, when editing the line (refined point in the middle and small translation), no updates come trough in the volumes select. When selecting the plane, the modifier stack doesn't also update anymore.
At the end, when selecting the plane and try to add a modifer, it pops to the modifer stack of the plane eventually, but resulting in a crash...
Any ideas what this issue would be?
Same setup in 3ds max 2022 had no problem at all...
Setup file in attachement.
Thanks in advance!
Replies (10)
MartinBeh
Great description of the problem, thanks very much! I wish all questions here on the forum would be that concise! Much appreciated.
What you see might be related to recent performance improvements for Vol Select - I will test it later and if I can repro will report this to the team.
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
MartinBeh
Just to follow up: I can repro this in 3ds Max 2025 and I did report it. No idea when/how this gets fixed, though, so we should think of some workaround...
MartinBeh
I can get it to crash even without the Edit Poly modifier, and without moving a spline vertex, just changing Vol Select options back and forth....
SamuelEeckhaut
Community Visitor
Community Visitor
Hi @MartinBeh,
Thanks for the reply and checking out the file. We actually use this modifier a lot for our environments and effects on the ground.
Also if we open older files in 2024, most of the Vol. Select using objects in our scene are not working anymore. Therefore we use 3ds Max 2022 for specific shots of our animations.
I hope there is a fix for this one as soon as possible (of course no intension to go back in software versions due features in 2024 and beyond)! We were already thinking for an alternative, but at the moment no ideas.
Thanks you for the report!
Sincerely,
MartinBeh
@SamuelEeckhaut - I suggest you also get in touch with official Autodesk support on this.
Some more findings from my side:
  • It does not crash for me when I do not use soft-selection in Vol Select
  • Adding a Sweep modifier to the line before using it as Vol Select mesh with soft-selection seems to avoid the immediate crashes - but refining the line and moving a vertex still crashes... this is not the case for non-shape based meshes. Something seems to broken with the change notification when a shape used by Vol Select is edited.
SamuelEeckhaut
Community Visitor
Community Visitor
@MartinBeh, I made a support ticket (Case 24182895) and mentioned this toppic here. I hope to get an answer soon ;)! Thanks for the extra information.
spacefrog_
Great analysis ! Could repo immediately too .
First i thought that the reason might be that somehow your max file was internally broken
But than i started a similar scene from scratch and same thing happened there too !
Josef Wienerroither
Software Developer & 3d Artist Hybrid
logan_foster_adsk
This issue was unfortunately introduced in 3ds Max 2024.2 due to some performance work that was done on the Volume Select modifier. It has been corrected in the 2026.0 release of 3ds Max.
"We fixed an issue that was introduced in 3ds Max 2024.2 with the Volume Select modifier where the modifier wasn't correctly detecting when the volume of an object was partially passing into the volume of another, thus not making a selection. This fix has been versioned so it will not affect scenes created between then and now, it will only be applied when a new Volume Select modifier is added to your object in the 2026 release of 3ds Max. MAXX-78825"
ArtT85
New Member
New Member
z
SamuelEeckhaut
Community Visitor
Community Visitor
Thank you for your reply. It seems we have to upgrade to 2026 then.
I have to say honestly, it's a pity there is no fix available for older versions for such issues.
We don't want to upgrade too fast because we have the experience the new versions of 3ds Max are not always stable and need some time and bug fixes. Also plugins we use are not always directly up to date for a new version of 3ds Max.
Thank you @MartinBeh and @spacefrog_ for the testing en reproducing the problem.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
