Hello, can you please describe why doesn't material rotating export to Unity, but UV mapping with Unwrap modifier does? Max 2020.1 22.0.0.757 Unity 2019.3.10.f1 . (I'm just arguing with a friend)
Solved by Diffus3d. Go to Solution.
Pretty sure whomever wrote that reply is correct. The rotate area in the material editor isn't changing your uvs, it's transforming them in whichever space you have selected. Think of it as a modifier. (As I understand it.)
Best Regards,
Alfred (AJ) DeFlaminis
Thanks for your answer! I will think it as a way to save UV unedited may be...
